Virtual Serial Port Com4 not present
Hi members after a reinstallation, COM 4 has disappeared and is therefore not selectable.
What can I do to fix that.
Cees , PA3CVI
  • Cees
    Cees Member ✭✭
    Solved:
    Found in FLEX community:
    1. Shut down SmartSDR CAT and SmartSDR (for that matter, close app open programs)
    2. Using Windows Explorer, navigate to where the installer is located
    3. The path is \Program Files\FlexRadio Systems\FlexVSP
    4. In that folder is the file: FlexVSPInstaller_xx.msi
    5. (where "xx" is 32 or 64 depending if your operating systems is a 32 or 64 bit.)
    6. Right click on it to get the context menu
    7. Select the Repair option
    8. Answer YES to any prompt and then wait while the repair executes. It may take a little while.
    9. When prompted to reboot your PC, select YES and reboot.
    Thanks Tim Ellison
