Does it make a difference if my DAX is only streaming at 427 kbps?
Van,
DAX at 427 Kbps to WSJT-X is normal.
If running more than one slice, increased demands on the remote site uplink bandwidth, DAX can go down into the 3xx Kbps range depending on resources.
You won't see errors, just that there will be fewer decodes shown on WSJT-X. It can be dramatic, like 30+ decodes per 15 second segment down to 5.
Same observation on 3.2.31 or 2.6.2; 6500 or 6600.
Blue indicator is good. If you can see activity (red slider) then I would look at FLdigi.
Dave
