Post v3.2.31 Upgrade Issues
Geds42
Since upgrading to V3.2.31 I am seeing random issues on Smart SDR for Windows. I have only used SSB since the upgrade. When changing bands from say 20 meters USB to 40 meters LSB, and then back to 20 meters, 20 meters might end up being set to LSB. The same may happen when going from 40 meters LSB to 20 meters USB and then back to 40 meters it may be set to USB. This happens randomly. Some days it may not happen and then other days it might happen 2 or 3 times. I have recreated all of my profiles, but still have this random issue.
The other issue I have come across once so far is that I changed bands from 20 meters to 40 meters. The radio changed bands to 40 meters (7.168) but the waterfall still showed the 20 meter frequency markers (14.250, 14.260, etc.) but had the 40 meter signals being displayed. I went to 17 meters and the waterfall markers were still for 20 meters. After a few more band changes, the waterfall finally had to correct frequency markers.
Are these know issues?
Thanks.
Thanks.
I might recommend a support case for this, but first, why not backup your profiles and do a reset on the radio. See if that solves your issue.
Hi Mike, I thought I would start here to see if these were known issues. I will back-up my profiles and try the reset. If that does not address the issue, I will open a support ticket.
Thanks.1
- 325 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 936 Third-Party Software
