Installation of v3.2.31 failing with ntdll error - anyone else?
unit9419
Member ✭
A previous version was running fine. But when I try to install 3.1.12 the installation barely begins and the the window closes with no error message. The application log produces event below each time. I have tried all the usual things such as rebooting, uninstalling the older version of SmartSDR, updating Windows, etc. Please advise
Faulting application name: SmartSDR_v3.2.31_Installer.tmp, version: 51.1052.0.0, time stamp: 0x5ec61809
Faulting module name: ntdll.dll, version: 10.0.17763.1852, time stamp: 0x5d8b408f
Exception code: 0xc0000374
Fault offset: 0x000e05e3
Faulting process id: 0x3bb8
Faulting application start time: 0x01d72e2f83fcce76
Faulting application path: C:\Users\rsmith\AppData\Local\Temp\is-SF9B7.tmp\SmartSDR_v3.2.31_Installer.tmp
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 836d65c5-5603-462c-b46b-f86428d43583
Faulting package full name:
Faulting package-relative application ID:
Try this, worked for me as the installer was failing.
- Right click on the .exe file for the new version where you downloaded it
- Select Troubleshoot compatibility
- Choose 'Try recommended settings'
- Click 'Test the program
I do not remember the exact error but ever since V3 came out on several Windows 10 computers I will get the same issue. I have found that if I let the error occur with computer restarts 3 or as much as 4 times the error finally stops and from that point on SmartSDR starts correctly. Like I said in another post it has been simpler just to let the error run its course of restarts then to document it and try to trouble shoot it.
In summary. Do the install and then try to start SmartSDR. Let it fail and restart the computer and try again. Do it up to 5 times before changing anything else. It works for me so maybe it will work for you.
John K3MA
[{"insert":"Thank you. However it is the install itself that is failing\n"}]0
Oh my goodness! it worked!!!! Thanks Rich!0
[{"insert":"Rich has the right idea but it didn't work for me. I right clicked on the executable, clicked on \"Compatibility\" tab, clicked on \"Compatibility mode\" check box and chose \"Windows 7\", click on \"Run this program as an administrator\". Then it ran through the installer...\n"}]0
Over 2 years later, having installed this on a number of PCs, I ran into a problem with 3.5.9 having the same issue.
Followed the instructions as above and it decided that it wanted to installed in Compatibility mode for Windows 8.
System is an old i5 running Windows 11 which was forced as it doesn't have the correct hardware.
Thank you Rich for your insight.0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
