Series of Error Messages on 6700
Dick Bean
I am getting a series of error messages:
Error PSL13V8A - 08.61
Error PSL13V8A - 09.43
Error PSL13V8A - 09.48 check fuse
Is that fuse user servicable?
Thanks!
****, K1HC
Hi ****,
As a first step I'd suggest putting your DMM across the power pole at the back of the rig. Measure the voltage on RX and then key down. I had this problem and discovered that my power supply was sagging under TX load.
Your fuse likely isn't blown but there may be an issue either with the PS or the path to the board - check for corrosion in connectors as well.
73 es gl,
Andy
VA3CW
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 217 DAX
- 391 SmartSDR API
- 87 Aurora
- 333 FLEX-8000 Signature Series
- 988 Maestro
- 960 Genius Products
- 351 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
- 844 Peripherals & Station Integration
