Series of Error Messages on 6700
I am getting a series of error messages:
Error PSL13V8A - 08.61
Error PSL13V8A - 09.43
Error PSL13V8A - 09.48 check fuse
Is that fuse user servicable?
Thanks!
****, K1HC
  • Andrew Mitchell
    Andrew Mitchell Member ✭✭
    Hi ****,
    As a first step I'd suggest putting your DMM across the power pole at the back of the rig. Measure the voltage on RX and then key down. I had this problem and discovered that my power supply was sagging under TX load.
    Your fuse likely isn't blown but there may be an issue either with the PS or the path to the board - check for corrosion in connectors as well.
    73 es gl,
    Andy
    VA3CW
