Why So Many Steps to Start (Restart) Flex 6600M After Upgrade?
I recently upgraded to v3.2.31. Everything went fine.
However, when I start or restart my 6600M, I need to first select "Operate" after a while. Then a screen comes up listing all the current (and all previous) software versions. I always want the latest version which is listed at the top. So I need to select "Run" again.
Not the end of the world but it would be nice if I could just press the On/Off button on the 6600M and the next thing I see is the slice / panadapter screen with the radio ready to go. Is it possible to do that without all the startup steps.
Seems like it used to work that way but maybe I am mistaken. Just curious.
AL, K0AD
Al,
In the “select a version” screen, tap the little gear in the lower left. Then enable “auto connect.”
2
Neil;
That did the trick. Thank you very much.
Al, K0AD
- 650 The Flea Market
- 152 SmartSDR+
- 263 SmartSDR CAT
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
