Maestro using SmartControl with multiFLEX
Has anyone with a Maestro tried SmartControl while two computers running SmartSDR are connected to the same Flex Radio using multiFLEX?
The reason I bring this up, is that I was testing the 3.2 upload on my old laptop. It went perfectly so I logged on to my 6400 using multiFLEX (my new laptop was already connected). My TeensyMaestro "B" side immediately showed the second laptop information. All of the B controls work on the second station to log on to the radio, and the A side controls the first. So if there were two operators sharing a Flex Radio using multiFLEX, each could see the status (frequency, mode, TX, Vol, etc) of the other operator if each had a TeensyMaestro at their end.
So does the Maestro in SmartControl mode operate the same way? Would this finally give shared stations that last bit of info needed to coexist on the same radio? I am not sure what the Maestro display shows when using SmartControl, but if it shows 2 active slices, this might be a cool thing.
Of course there is a down side risk to operating this way... Whoever has a TeensyMaestro (or Maestro if it works the same way) can mess up their fellow operator by turning the wrong control set. Imagine listening for your shot at a DX station when your slice suddenly tunes off somewhere because your buddy accidentally grabbed the wrong VFO knob...
Hi @KD0RC
Yes, I just tested it with one client on a 6600M and the other client on Win 10.
I then took my Maestro with SmartControl and was able to select one or the other to control.
73, Mike
Thanks Mike. When I saw how my gizmo worked in this scenario, I thought the Maestro might do the same.
So for multiple operators using one radio, the Maestro can be used to keep track of where your buddy is operating. This could be pretty cool if one operator is running a frequency while the other is hunting multipliers. Could also be a great way for a club trustee to monitor station usage.
Hi Len
That seems to work.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
