How to connect a wireless mouse to a Flex6600M Radio?
Wireless mouse connection to a Radio
  • Gabor
    Gabor Member
    Answer ✓
    Ye, it did answer the question! Thank you all!
    73's ,KZ2A
  • Tim - W4TME
    The M model radios are designed to be used with the touch screen, not a mouse and/or keyboard. There are no facilities to do this. If you want to operate the radio with a mouse, you will have to connect to the radio using SmartSDR for Windows.
  • Thomas NE7X
    Thomas NE7X Member ✭✭
    This is disappointing to read Flex Radio's stance on this topic for the non-SmartSDR Windows PC users.
    NE7X...
  • Gabor
    Gabor Member
    Thank You Tim-W4TME and Thomas NE7X
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    The screen in an M/Maestro is an OEM windows tablet. Most tablets are touch oriented, not generally mouseable.
  • Bill NE1B
    Bill NE1B Member ✭✭✭
    The Apple iPAD iOS SmartSDR (non-SmartSDR Windows) can have a blue tooth mouse to run the 6600M radio.
    de NE1B
  • Steve KD2OM
    Steve KD2OM Member ✭✭
    I use the Griffin Powermate with the iPad and iOS operating system. Although not a mouse, it works ok and gives an easier way PTT.
    Steve KD2OM
