Can't get DAX to TX.
I'm a shiny new 2nd owner of a 6600M with lots to learn. I have my radio, PC and WAN send working but having trouble getting N1MM to modulate the radio. I see the TX slider on the PC going red and moving but no PTT and or output to the radio.
Any ideas are appritiated.
73, Gerry VE6LB
73, Gerry VE6LB
I missed the N1MM+ comment. So, you are trying to get .wav files to transmit? If they do not activate PTT, then check the Config menu for the appropriate PTT Com Port. I use COM5 for PTT on Slice A. Additionally, check the Path to the correct wav file folder. There is a pdf Instruction sheet for setting up N1MM+ for the Flex. Check the Documentation section of the Flex website.
What is the Dax and Cat configuration?
More information needed. Is this for SSB, CW or Digital mode? If Digital, the program such as WSJT-X modulates the radio using the DAX On. Do you have a microphone connected directly to the radio? If so, have you selected the correct microphone in the pull-down menu options? See screen shot.
- 633 The Flea Market
- 130 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
