Staion Integration using Rasberry PI's?
Is anyone doing interesting stuff in the shack utilizing Rasberry PI's ?
I use them a lot to control devices and to talk to my 6700 via ethernet.
I think it would be neat/fun to use ALEXA and a PI for station control.
  • David Decoons, wo2x
    Check out Node Red. Runs on a Pi and we've been integrating a lot of equipment and software, including Flex radios, rotors, amps, tuners, etc.
    nodered-hamradio@groups.io | Home
  • Steve KD2OM
    Steve KD2OM Member ✭✭
    Is there a Node-Red flow to control a AntennaGenius 8x2 switch?
    Steve KD2OM
  • Alan
    Alan Member ✭✭✭✭
    Steve
    Dave, WO2X, has published an Antenna Genius Flow. Download the "AG2x8_with_N1MM_integration.json" file from the Ham Radio Node-Red Forum.
    Here is a link to Daves files on the forum:
    Alan. WA9WUD
    @Bill Bailey
    You have 2 of the best NodeRed guys where. Grab a PI and dig in. :)
  • Steve KD2OM
    I have Mike. Alan and Dave have both helped. I have the main thing, the AG switch working fine and am slowly finding my way around NodeRED. I am very familiar with the Pi and Linux, this graphical method is not so easy for me.
    Steve KD2OM
    Yes, Node Red is a lot of fun.
    Conny, N5HC took my 2x8 flow and added to it. The one I have posted in the file section is the result of his and my contributions. It natively supports 2 stacked 2x8 switches and the code is there to add the additional nodes to go with a stack of four 2x8 switches for a 2x32 setup :-)
    I only have three antennas.....
