SmartSDR and New Radio
Hi Smitty, How are you connected? For example, in my shack, I have my 6400 plugged into a network switch. My laptop is also plugged into the switch. The switch is plugged into my modem/router. I don't have to do anything special - it just all connects.
Let us know how you are configured and we will give you a hand.
I am connected directly to my hub (router) computer and radio...nothing special0
Meaning both your computer and your radio are each individually connected to your router?
yes.....my modem has a 4 port router0
OK, that is a very normal way to hook up. To determine if there is a problem with the radio, try connecting an ethernet cable directly from your computer to the radio and start SmartSDR. If that works reliably, then the issue is probably a setting in your router.
If that does not work, it is probably best to submit a help desk ticket with Flex.
its a setting in the router so may go in an set it up as a static ip it seems not to like DHCP
Smitty0 -
There are cases where a static IP is preferred, but normally, DHCP is the way to go. I don't know enough about the various routers and internet providers, but if you list your make and model modem/router and your internet provider, there are folks on here who can probably give you the definitive answer.
i finally figured it out...well stumbled across the fix. I had VM software running in the background and it was blocking the radio after setting the IP to static all is well....I will have to take a further look into the happenstance tomorrow after I have a few less **** and a good nights sleep. My thanks to all who chimed in with assistance.
Smitty (K4 Oh I'm WEIRD)0
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
