Headset
Lee VE6MKM
I have just upgraded to a 6400 from a 3000. I would like to use a Yamaha CM500 Headset with the 6400 it is what I used with the 3000. What mic would I select from the choices given? I had to use the battery pack with the 3000 yes or no with the 6400. Would I also have to turn on the Bias or leave it off. Appreciate any guidance.
Headphones
Frequency Response
20 Hz
Sensitivity
96 dB/mW
Impedance
120 Ohm
Microphone
Microphone Technology
dynamic
Impedance
600 Ohm
Response Bandwidth
100 Hz
Lee VE6MKM
Headphones
Frequency Response
20 Hz
Sensitivity
96 dB/mW
Impedance
120 Ohm
Microphone
dynamic
Impedance
600 Ohm
Response Bandwidth
100 Hz
Lee VE6MKM
solved0
Hello Lee ARS Ve6mkm...did you get any comments to your question? Just curious on this subject...de KE1AV0
Did find the fix had to vary search question it was in the forums.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
