New version snag.(2.31)
Jim Brinza
Hi all I had to **** dc power to finish the upgrade but CAT wont load UNHANDLED ERROR message.
Thoughts?
Did you read the release notes before installing? This situation was covered in the release notes. The new version of SmartSDR v3.2.31 has an updated FlexVSP driver that is not downward compatible with previous versions of SmartSDR. I suspect you are running an older version of CAT. The version number is in the unhandled exception and it if is not v3.2.31, that is your issue. Make sure you are running the new v3.2.31 version of CAT.
I saw that in the notes BUT Icon says 3.2.31 What more should I check?
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
