SmartSDR 3.1.12.51 unhandled error
Computer:
I7-9700k, 16G RAM.
Win10 - 1903
Build 18362.900
I could swear this worked when I installed 3.12 shortly after the release, but I may have been on Maestro the entire time.
Here is the error:
Is it ok to uninstall/reinstall Smartsdr?
Keith - AC9S
This morning (6/9/2020) windows pushed an update when I did a restart.
Now I'm getting an unhandled error message with SSDR 2.1.12.51
The OS is Windows10 Home, version 2004. Build 19041.685
Is anyone else experiencing this? I'm wondering what I need to do to fix it?
Thanks.
73 Mike K9MK
Correction: Make that this morning 12/9/2020
Yes. I have the same Build of Windows 10 Home and I am getting the unhandled error too! If I click OK, it shuts down SmartSDR 3.1.12. If I ignore it, I can continue running SmartSDR, but the error messages continue to "pile up".
73, Bill NE1B
Good Morning fellow Flex users. I have been experiencing "unhandled errors" while running the V3.1.12 software on Win 10 Build 19042.868. I have snapshots of the errors..but don't see a way to attach them here. The only cure is to over install the software to correct it. I have tried to do a clean uninstall and re install, however after a day or so, it reverts back to this error. Are there any known conflicts with Windows or other apps that may be contributing to this error. Plesae help me fix this..so that I can convince my fellow ham (the station owner to which I am able to operate) from switching off the Flex platform. :):) I LOVE FLEXRADIO..and want to keep it availble to use. I live in an apartment and this is my only way to be on HF HI HI.. Here are the error photos.. Regards VE3MGQ :)0
@Bill NE1B I suspect you have a FlexControl connected to your PC. If my assumption is correct, then you need to change the com port number to a high number by using the following HelPDesk procedure How to Change the Com Port Assignment for a FlexControl
@rcleroy You are not actually solving the problem by reinstalling the SmartSDR software. As a matter of fact, you could actually be exacerbating the problem by doing that. What you need to do is open a HelpDesk ticket and send the unhandled exception error message detail to the support techs.
Thank you Tim! That fixed it. Flex Control is more reliable and no "Unhandled Errors" since putting the Flex Control on a higher Com Port. 73, Bill NE1B
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
