Poweramplifier HF 200Watt- Flex6400
Cees
[{"insert":"I'm looking for a suitable "},{"attributes":{"code-block":true},"insert":"\n"},{"insert":"affordable HF poweramplifier "},{"attributes":{"code-block":true},"insert":"\n"},{"insert":"200 Watt that is suitable "},{"attributes":{"code-block":true},"insert":"\n"},{"insert":"for my Flex6400 radio. "},{"attributes":{"code-block":true},"insert":"\n"},{"insert":"Can anyone advise me?"},{"attributes":{"code-block":true},"insert":"\n"},{"insert":"Regards, Cees, PA3CVI"},{"attributes":{"code-block":true},"insert":"\n"},{"insert":"\n"}]
[{"insert":"I am looking for a suitable affordable HF power amplifier 200 Watt that is suitable for my Flex6400 radio. Can anyone advise me?"},{"attributes":{"code-block":true},"insert":"\n"},{"insert":"\n"}]0
...that's a big step - from 100 to 200 W :-)
Chris
3 db. That's 1/2 an S unit. It might make a difference. 500 watts would be a whole S unit.
Bob
put up a better higher gain (3db gain) Antenna this way you also benefit with getting MORE ERP (Effective Radiated Power) and RX signal strength to the radio with out having to purchase a little 200W AMP.
Check out the non US Amp builders they may have one that is 5 watt's in and 200 watts out for the CB band folks.
- 650 The Flea Market
- 152 SmartSDR+
- 263 SmartSDR CAT
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
