PowerSDR: How to remove offset for DIGL/DIGU
SP2EWQ
Hi,
I can see PowerSDR introduces the offset of +1kHz
while reporting the frequency via the CAT if DIGU or DIGL are activated.
My question:
How to remove that offset, please, as there are aplications for which
that is very confusing.
Best regards,
Alec SP2EWQ
Hi Alec,
Not sure if this will help your problem but...
I am not in front of the radio right now but I believe that in the DIGU/DIGL modes if you look in the "DSP" tab (I think that's where it is) you will find an "Offset" entry box. See if changing that value helps.
73, Mark K5XH
Mark,
thank You very much for Your suggestion.
I have looked through the settings and found that offset in the CAT folder.
Big thanks for Your help.
Stay safe,
Alec
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
