Internet switch, Sonoff or KMtronic?
My question relates to the remote internet switch peripheral. In the YouTube of your boat house shack you recommended the KMtronic Ethernet LAN switch. In the QSO Today YouTube, you recommend the WiFi Sonoff. Since you are not a fan of WiFi, why the move away from KMtronic? Thanks in advance. Rusty - W3US
Best Answers
If I may respond, as I have also watched Mike' videos.
Mike cautions the use of WiFi for devices requiring low latency and no loss of packets with no buffering. He brings this up often when discussing comparing WiFi to ethernet cable for the Flex Server, Clients, and third party applications.
Using WiFi to access a web based switch is not affected by latency or loss of packets, so this is why one could be agnostic on the choice.
I believe Mike introduced the Sonoff as a easy to deploy web switch.
Mike uses KMTronics, for one, because it can be interfaced easily using Node-Red.
Mike, please correct anything I have not stated correctly.
Alan
WA9WUD
I am using a Sonoff 4CH PRO R3 4 Channel Din Rail Mounting Wireless switch and I am very happy with it. In fact I’ve just ordered another one. Several versions are available, however I would recommend the the “PRO R3” version because it can operate off 120/240 volts or 12Volts DC. The cost delivered in VK was AUD48 (around USD32) I particularly like the iPhone interface which give you tactile as well as visual confirmation of remote switching operation. The Chinglish instructions are a little iffy, but if I can work them out then anyone can. Winston VK7WH
- 384 Community Topics
- 643 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
