AM sidebands bigger than carrier
Sprocket
Have a new 6400 and am running Smart SDR for Mac OS. Still learning how to operate the Flex but on AM the sidebands appear to have as much or more gain than my carrier. This is especially evident on 160 there I also have a scratchy noise while transmitting. Any suggestions? I have been reading the manual(s) but can't figure out what need to be changed. The microphone is an Inrad 629.
Sprocket
Sprocket
Best Answers
Bret thanks for the reply. You're right it turns out the mic is defective. I'm sending it back for a refund and buying something else.
Steve
K1MV0 -
KD0RC I'll give that a try thanks for the tip
Steve
K1MV0
Got this issuer fixed!!! It appears the Inrad 629 mic is defective, the connector that connects into the base arcs when touched causing lots of noise and making the mic unusable. I tried the handheld mic and no more interference. Now to go shopping for a new mic and return the Inrad to Flex.
Still learning where to set levels when transmitting. If anyone has suggestions let me know I get an echo when I transmit and that's the next thing to chase down.0 -
It sounds like you have the Mon turned on. Turn that off and the echo should go away.
sounds more like the MIC element is grounded to the shell of the microphone and your picking hum from your body (ground loop), you may be able to tear the mic apart and isolate the mic element from the shell of the microphone body most MIC elements have a + and a - connection for a balanced MIC should be isolated from the radio chassis ground.
connector on the Inrad 629 was dirty, quick shot of Deoxit solved the problem. Thanks for the help.
73 Steve
K1MV0
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
