Volume goes up when closing SSDR also when clicking on mode buttons.
Using amplified speaker off of back of flexradio. Not using remote audio.
Running radio that is attached to router and computer is wifi to the router.
As i shut down the software it gets like 1/3rd louder.
Also clicking on the modes-usb-lsb-am- filter width several times back and forth etc etc makes volume come up louder too.
If this is in a trouble ticket i apologize could not find it.
Does it just sound louder or does the volume slide indicator actually move?
When the radio does weird things like this save and export your profiles and do a hard reset and see if that takes care of it BEFORE you reload your profiles
This may be all you need to do and will only take about 5 minutes to do this at least for me
Thanks for replies. To Pat_W5WTH no the sliders do not move.
And with the Sound card software update worked wonders.
You have card drivers and then the App that goes with soundcard so i updated and went through settings on
sound properties and took care of it.
My guess surround sound messes with it. Semi-muting sound somehow.
I have not ever had this problem before so call it fixed!
73, Jeff
Hi Jeff,
I'm curious about how the sound card can have any effect if you are plugging your amplified speakers into the radio directly.
Can you please clarify?
Geoff AB6BT
DAX is the answer !
- 112 SmartSDR+
- 944 Maestro
