Changing "Station: <computer name>" in SmartSDR
Brock
My first time configuration of my new-to-me 6400 was done with an old computer resurrected for the purpose. It got a fresh install of Windows 10, then the Flex software was installed.
The default name of the computer from the install seems to be in the bottom of the SmartSDR window... "Station: computer name". I changed the name of the computer in the Windows settings so that I could identify it separately from a laptop I may also use. However, that old name seems to be permanently burned into SmartSDR.
Is there a way to change it, or have it re-read this from the computer? Or perhaps I need to uninstall and re-install the Flex software?
Hi Brock, in SmartSDR you can click on the name and type over it to change it.
I have tried that and the computer name changes until I turn the radio off and the computer off. When I turn it back on the original name is back. How do I get it to change on a permanent basis?
Did you hit "Enter" when you had changed the name? If not, it changes back when you switch off SSDR.
- 364 Community Topics
- 625 The Flea Market
- 8.1K Software
- 71 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 254 SmartSDR CAT
- 189 DAX
- 379 SmartSDR API
- 31 Aurora
- 235 FLEX-8000 Signature Series
- 934 Maestro
- 54 FlexControl
- 913 Genius Products
- 331 Tuner Genius XL
- 122 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 448 Remote Operation (SmartLink)
- 772 Peripherals & Station Integration
- 989 Third-Party Software
