can i use ameritron al 80 amp with the flex 6400
Chuck L
You can use a relay buffer such as the Ameritron AR704B. That will give you extra protection for the amp keying line.
This is my favorite. Using it on an 6600 and AL80B. Use an 3.5mm TRS to dual RCA splitter Y cable to peel out the active low and active high connections on the UKA-3.
Ron
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
