Flex 6600 with a VHF transverter full band coverage
So 29 MHz gives out 145 MHZ and 30 MHz gives out 146.
How can the 146 to 148 portion of the band be used?
Flexradio does not transmit above 30MHz.
Best Answers
If you use the transverter outputs, you can transmit where you need. If you use the antenna outputs, it is restricted to Ham bands.
Q5 .Vhf Transverter with the flex 6400 M covers the whole band 144.Mhz to 148.Mhz. Jr .. KO4OO
When using the transverter port, the radio is programmed not to limit the bandwidth on 10 meters. Thus it allows the transverter to operate to its designed BW limits. On the ANT1 and ANT2 ports the BW is limited to the normal band prescribed by the FCC.
Hello Demetri, The traditional use of VHF and UHF transverters has been for use in the weak signal portion of the band the transverter is built and tuned for. Ten meters was utilized as an IF as most HF radios have good sensitivity, selectivity and all round decent performance features in the HF bands. Then coupled with a superior performance transverter with sequenced mast mounted preamps and all of the super high performance rig-a-marrow gets you a system that will hear the weakest of weak signals in terrestrial or EME uses. These systems traditionally have the antennas, preamps, and transverter front ends tweaked for narrow performance frequency ranges hopefully with the ability to curtail intermod and out of band signals being translated into the your TEN meter radios' passband...
Another problem either way is you would run into is the transmit end of band at 29.700 unless they have EXTENDED TRANSMIT programming. That usually is NOT a problem in traditional use region of the weak signal portion of the band. One might run into issues doing satellites as the repeater and sat regions may overlap in the 145 region.
I noted Ted's comment about the Flex continuing tuning with the Xverter input...
IF you MUST use a transverter in the regions above where the 29.700 will transmit, you have three choices.
The first and traditionally recommended by weak signal enthusiasts is to buy a 2 meter FM radio if you're looking to operate FM repeaters.... OR if you are looking for weak signal and fm ability get an ALL MODE that retunes the radio in the other band segments with a tracking or band selected front end...
OR either Modify your transverter with a selectable IF Local Oscillator Crystal that will translate 148 ish signals down to within the transmittable regions of your HF radio. And you also may desire a lower type performance transverter that can handle the wide open bandpass... Be prepared for a local full scale repeater desensing your weak signal work...That sort of degradation is VERY fustrating.
Many high end transverters Already have a local oscillator selector for a second band segment. I know of none them that retune for the second band segment. If you're honestly looking for superior band coverage, I would recommend building yourself a finely tuned very high performance transverter with tracking or selectable front ends. Either way mast preamps and high performance antennas are going to be way out of their performance window.
IF all you desire is a repeater radio, see above^^^ or RETUNE the transverter system for its highest performance in the window of band you desire best performance. If you are using reasonably prices transverters, BUY a second one tuned for your second segment. I'd also utilize completely different antennas for the other utilization.
You didn't state your intended purpose, so I tried to cover the colloquial uses...
Sincerely,
Erika KØDD
I am using the UR3LMZ dual band transverter with my Flex 6400M and I am able to transmit on 144-148 MHz. There is a push button on the unit that changes the LO frequency by 2 MHz to provide a wider frequency range.1
Thank you! Confirmed from the guys at Q5 Signal. It is also very clear in the 6600 manual: • Transverter (XVTR) IF Output Port
100 KHz - 54 MHz
Thanks Ted, 73-1 -
thanks for all the help guys! I have ordered the Q5 VHF transverter and waiting for it. 73!!!0
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
