Ver.3, Maestro and antenna switching
I am using a 6700 on a PC running Ver.3 with two slices running... My Antenna Genius is controlled by the same computer and follows perfectly...Now with the Maestro running too thins work great until the PC changes to another band the Maestro does not know the antenna has changed so when it transmits it thinks it is still on the correct antenna but is not and there is no way of knowing of the change until the SWR goes ape... example... the PC is on 40 meters slice A antenna 1 and on 6 meters slice B antenna 2.. so is the Maestro... Now if the PC changes slice A to 17 meters, for example, the Slice A antenna changes Ant. 1 to the 17 meter antenna but the Maestro still thinks its on 40 meters and there is no way the remote stations knows this until the Maestro transmits on the wrong antenna and the SWR goes off the chart..... The only way I have been able to mitigate this is by telephoning the remote to say we are changing antennas..... seems a counter productive method to remoting.... any ideas??
Tnx, Bruce AH0U
What version of AG software are you using? Earlier versions of the AG firmware used the Windows AG client to track the Flex. Newer versions track the Flex directly from the AG. I had your problem when I was using older AG firmware.
Asher K0AU
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
