Flex 6300 audio has gone flat
My audio has gone flat on my Flex 6300.
I rebooted it and it was fine for a day then went flat again.
I also only have 60 watts on 80 meters.
So me thinks I need to send it in to get it repaired.
Any comments?
DJ
VA3KBC
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    I'm not really sure what you mean by your audio has gone 'flat'. Could you describe the symptoms in more detail?
  • Sorry for not getting back.
    I had to do a hard reboot and reset my audio EQ.
    All is good now. Get very very good audio reports. :)
  • VE7ATJ_Don
    OK, no worries. Glad to hear the 'reboot' did the trick :-) If you like the way it sounds, you may also want to 'save' the settings in your own profile.
