Flex 6300 Audio Issues
Robert - KV4JO
My Flex 6300 has three issues.
- Once a week (estimate) the radio spontaneously makes a very loud buzzing sound without any reason that I can determine. No response to software controls for volume, mute, etc. therefore a hard shut down (holding the power button for 5-10 seconds) is required to stop the buzzing.
- Raising the volume level causes very loud crackling and popping sounds. Backing off the volume stops the popping and crackling. The same result is possible by raising the microphone volume or speaking loudly into the mike. This is done in the receive mode, NOT in transmit mode (MOX). As a side note while listening with headphones, speakers muted, in receive mode speaking loudly into the mike causes the loud pops and cracks in the headphones. While transmitting into a dummy load and monitoring myself via the MON button I hear my voice as expected, but get the pops and crackling sounds at normal to high levels of audio drive.
- Entering and exiting transmit (key down then key up) the external powered speakers (connected via the rear 1/8 inch stereo jack) thump noticeably.
My opinion is that all these symptoms are related and have a common cause. I wonder if others have had such problems, I am sure that I am not the only person the experience these types of issues. Should I open a ticket to proceed with a solution, or is there something that I can do at my home shack to solve the problems?
Bob Paluf, KV4JO
I'm thinking that these may indeed be related. I think opening up a help desk ticket is a good idea.
Thanks Don. I will do so.
- 650 The Flea Market
- 154 SmartSDR+
- 49 Aurora
- 964 Maestro
- 938 Genius Products
