Flex 6400 M not linked to computer what is the best Update 3 1 12 or 3 1 8 ?
My 6400M is used only like a transceiver: No computer , no remote control.
Some time it change the software a the start by asking me 3-1-8 instead of the 3-1-12.
Tell me please the good one version? I have some wrong start some time... best 73 f6eju jean claude
Best Answers
Bon Jour Jean Claude, 3.1.12 is the right one to use. 3.1.8 has the potential to cause SD Card corruption.
Len, KD0RC
3 -
Ok good find by myself...
tks for help
all is fine now
jean claude f6eju
Glad you found it Jean Claude! I have a plain 6400 (non-M), so I am not much help...
FIRST upgrade the front of the radio, when you first turn it on it should have a list of different versions of software on the screen CLICK on 3.1.12, let it do it's thing.
Then on your computer be sure to download and install 3.1.12 and then you should be done.
if you don't see the Multi-versions on the Main Radio screen when you first turn on the radio then you will have to do a couple key clicks on the radio screen to log it off (NOT the power button) so the version screen will come on.
BUT it is VERY important to update the M series Radio first then do SmartSDR.
if you don't see the version window on the radio front panel, From the Radio Click Menu, then about 1/3 of the way to the right on the grey screen you will see a "Switch Version" screen, Click it and you will be disconnected from the radio and it will put you at the version screen, Now click on the "3.1.12" and the radio will update the Control head and the Radio.
Hope this helps
Tks Bret all is clear now. 73 f6eju jean claude :)
3.1.12 is the latest
Len.
Thank you.
I have to reload the 3.1.12.
However it is the flex that have decided to go back to the 3.1.8.
I have to find out how to go back.
I am so seeking for the procedure... :) Yes old timer are turning a bit lazy , forgive me hi
73 jean claude far french riviera ;) f6eju
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 827 Peripherals & Station Integration
- 145 Amateur Radio Interests
