Red flashing lights 6
My flex 6600 will not power down or up due to 6 red flashing lights.
Any help?
Lee
Hi Lee, From the FLEX-6400/FLEX-6600 Hardware Reference Manual page 18:
Error Conditions Certain hardware and software error conditions cause the radio to stop operating and display an error code by flashing the Power button light as follows:
• One red flash: Fan malfunction
• Two red flashes: Software crash
• Three red flashes: Boot failure
• Four red flashes: Input power over voltage
• Five red flashes: CPU overcurrent
• Six red flashes: Input power under voltage
It looks like an under voltage situation. You might try powering off your power supply and unplugging and re-plugging the Anderson Power Pole connectors at the back of the radio to see if dirty contacts are the culprit. If not, check the voltage of the power supply to see if that is the issue. If possible, try a different supply.
Thank you Len. Cleaned the power cable and all power connectors turned on the Flex 6600 and she fired
up. The radio is working fine now. Thanks for your help. Lee
I'm glad that was all that was wrong!
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 827 Peripherals & Station Integration
- 145 Amateur Radio Interests
