Record My CW Sending
Geoff AB6BT
Geoff AB6BT Member ✭✭✭
I'm trying to record me sending CW with Audacity. It seems as though the only DAX sources are DAX RX channels.
Any suggestions?
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    Geoff,
    To record actual transmitted signal , use the “FDX” in lower left corner, open a second panadapter , set the DAX to 2, RX antenna to “XVTR” , frequency to the required tone, enable slice B in DAX control panel, Audacity to DAX Audio 2. Now you will record your actual transmitted signal. You can mute the audio output of pan B so the slight delay won’t upset your sending , but your brain can eventually figure it out .
    This should help,
    Dudley , WA5QPZ
  • AF3K
    AF3K Member ✭✭
    Geoff,
    I tried Dudley's suggestion and it works great! https://www.screencast.com/t/CdLOd6d6IcUb .
    John AF3K
  • Geoff AB6BT
    Hey Dudley,
    That makes sense and it did not occur to me to try that approach.
    I'll give it a shot.
    Thanks es 73,
    Geoff
  • Geoff AB6BT
    Hi Dudley,
    Works great. Thanks for the clue.
    73-->Geoff
  • Dudley  WA5QPZ
    Glad it worked out for you.
    Dudley
