Record My CW Sending
I'm trying to record me sending CW with Audacity. It seems as though the only DAX sources are DAX RX channels.
Any suggestions?
Geoff,
To record actual transmitted signal , use the “FDX” in lower left corner, open a second panadapter , set the DAX to 2, RX antenna to “XVTR” , frequency to the required tone, enable slice B in DAX control panel, Audacity to DAX Audio 2. Now you will record your actual transmitted signal. You can mute the audio output of pan B so the slight delay won’t upset your sending , but your brain can eventually figure it out .
This should help,
Dudley , WA5QPZ
Geoff,
I tried Dudley's suggestion and it works great! https://www.screencast.com/t/CdLOd6d6IcUb .
John AF3K
Hey Dudley,
That makes sense and it did not occur to me to try that approach.
I'll give it a shot.
Thanks es 73,
Geoff
Hi Dudley,
Works great. Thanks for the clue.
73-->Geoff
Glad it worked out for you.
Dudley
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
