Station Rack mounts
I am looking for suggestions on rack mounts...
I want to move all my hardware to a rack assembly....
6700, pgxl, 4o3a 8x2, Tuner genius (when released), power supply, network switch, ground bar, power ****...rotor control
The goal is to integrate the complete station into a roll around rack.
Tim WA5YOM
Tim,
I am in THAT very process right now. I found a local club member who was an IT guy and picked his brain about this. He said get as tall a rack as you can afford or can fit in your space and place the item as par apart as you can since cooling can be an issue.
I figure the Modem which has one wired port would go to the router which as at least 2 wire ports. I will run one port to each of the switches.
I tried to future proof as much as I can. I got gigbit unmanaged switches, one for just flex radio stuff and the other switch for the Iot (internet of things). These switches have 24 ports each. I will say that the ports fill up fast.
I put the rack mounted 12 volt power supply and the 120 volt power strips in the middle of the rack.
I built up from the power supplies/ power **** with all things internet / WiFi/ LAN and down with all things radio
As for all of the radios; I plan to move, not only the radio / amp and power supply, VHF and UHF transverters and amps as well as my GMRS repeater to the bottom .
The 6600 and PGXL are the heaviest things I have and are on the bottom.
Hope this helps
Jeff
Tim,
This is where the project stands right now.
Jeff
Look really good, looks a lot like mine except I wish I had a 4 rail rack like your rack instead of the 2 rail other then the radio here is the 6700.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
