Profile issue
Michael N3LI
Just a quick question. Using SSDR for Mac, When I go to save a profile, the window shows up without any text in the "Save, Copy, and text only in the "delete portion of the window window shot is included. Is this possibly a bug, or do I have a one-off situation? This shows up in global, Transmit and Mic profiles.
Hi Michael, I confirm the same issue here (Flex6500, MacOS Big Sur 11.1).
Jean-Luc / F5JRC
Thanks, Jean-Luc. I'm using a 6600, also with Big Sur.
If you see the >> Icon on Big sur, you need to enlarge the window. Also here, the blank space above the Delete button now contains the name of the buttons. I don't know if this is something that had been fixed with the latest Big Sur or the latest App update but it is fixed.0
Whichever update fixed it, it is fixed. There are now a row of buttons at the top of the profiles window, where once was a dropdown menu, so I'm assuming a program update took care of the issue, compare old window above with new.
- 73 Mike N3LI -
- 385 Community Topics
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
