no transmit on 60 meters
kb9zm
I have a 6400 with SmartSDR v3.1.12 that has been working fine on 60meter Ft8. When I tried tonight it will not transmit on 60 meters it works fine on the other bands. How can I fix this problem?
Be sure you are on the exact correct frequency for the channel and your TX bandwidth is not beyond 2800 .
Dudley, WA5QPZ
After additional checking I found that under PHNE the high cutoff was set to high. I turned it back down and it is transmitting now. Thank You Dudley your comment let me know where to look.1
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
