no transmit on 60 meters
I have a 6400 with SmartSDR v3.1.12 that has been working fine on 60meter Ft8. When I tried tonight it will not transmit on 60 meters it works fine on the other bands. How can I fix this problem?
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    Be sure you are on the exact correct frequency for the channel and your TX bandwidth is not beyond 2800 .
    Dudley, WA5QPZ
  • kb9zm
    kb9zm Member ✭✭
    After additional checking I found that under PHNE the high cutoff was set to high. I turned it back down and it is transmitting now. Thank You Dudley your comment let me know where to look.
