Remote On Plug and Play solution for the European market ...
So - if anyone has a simple and inexpensive solution to this then I would be grateful if you let me know :)
Stay safe and best 73's
Mikael (SM0LPO/SF0A)
(www.sm0lpo.se)
Hi Mikael, Here is what I use here in the US. It is powered from 7 - 32 VDC, so it can run from a 12 v source easily. It is around $22 USD, so not a big risk if it does not work. You can download a free app onto your phone to get remote access to it. I use one channel to turn the rig on and off, and the other three channels to switch antennas. I think it will work in EU because it is just a WiFi connected device. If you go to the Amazon site, you could ask if it works in Europe.
Len, KD0RC
I’m using this Ethernet relay module. Works perfect, you can use an iPhone/Android app or web interface to change relay status.
73 Hans Christian LA9AKA
This is what I did. Simple, effective, cheap.
http://www.whiskeytangohotel.com/2020/04/flexradio-remote-control-onoff-state.html
I just built this and tested it.
https://community.flexradio.com/discussion/8023926/easy-to-install-web-relay/p1?new=1
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
