Sorting memories
Is there any way to sort/order the entries in memory on a Maestro?
Not a big issue but darn frustrating to have to remember where in the list the net is that you are looking for is in order to select it. Even sorted by frequency would be helpful but by name would be ideal.
@Doug This is not a current feature in the Maestro software. There is however a feature request, J8283, to add it.
Double click the column heading
Hi Doug, there sure is. Open the Memory Channels window and click on the title of the column that you want to sort by. Click again to reverse the sort (A - Z or Z - A).
Len, KD0RC
Geoff & Len,
Thanks for the fast reply and it would be great if I were running software on a computer but I have no columns and no way of clicking on a Maestro.
OK, well no Maestro here so passing the ball...
Edited the original question to include reference to the maestro since posting it in the maestro section didn't let anyone know that the question was aimed at the maestro.
Thanks for the attempt.
47 & 73
Doug:
Bring up the SSDR memory screen. If you click on the column label (Group,Frequency, Name, etc) the screen will be sorted per that column.
I edit/label my memories in the "GROUP" column per band (160,80,40 etc) and by function (NET, FT8, CW) . By clicking on the "GROUP" column I can sort the screen by function. The "GROUP" column alternates between numeric and alpha each time you click on it. The sort appears numerically by the lowest number at the top and alphabetically (z at the top). The secondary sort in this case appears to be by frequency. Play with this scheme to see if it helps or give you some ideas. This is one way and probably not the best. I do similar labeling with profiles to order the display sequence.
Gayle K0FLY
Sorry I missed Maestro i your post. It looks like you can edit the memory name with the Maestro. Bring up the Memory Menu and edit the name with your net name.
Gayle K0FLY
Having now spent 5 hours playing with the screens and searching in the manual for a solution I come to the conclusion that there is no way to put the memories in any specific order on the Maestro. They are not even displayed in the order they were entered. Changing Name, Group and Owner have no impact even after a shutdown and restart. (thought maybe changes wouldn't take effect until reloaded)
Not seeing much point in having memories on the Maestro if I can manually enter in less time than it takes me to find it in the memory list. So sad.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
