Heil Pro 7 w/HC7 Dyanmic: Bias or no Bias? +20 db Y/N? Default = HM Pro ? Mix messages in thread
John AD6NR
I don't have any Heil products.
If the mic cartridge is dynamic then it its passive and does not require the bias to be turned on.
As far as the gain setting, try it both ways and see what works best.
Geoff AB6BT
I Use the Pro 7 all the time. " BIAS OFF as Geoff says. My mic drives the input VU meter just into the RED with MIC gain set at "90" and the pre amp off. With pre amp on the mic drives the radio just into the RED at 45. I run my radio with the peak indicator hovering around -5 to -10 and the pre anp off.
Gayle K0FLY
I should add that the mic is about 1 inch from my mouth.
Gayle
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
