New software
I agree as I am having difficulties trying to get fldigi working with the flex 6700. Right now I cannot get CAT to work with fldigi - frequency display does not match the flex but I can key up the radio through fldigi. This should be a no brainer. I should add that I am able to set a frequency in fldigi and it does transfer to the flex but not the other way.
How to activate copies of instances A-B-C…. FLdigi for FlexRadio SSDR 6600
Run FLdigi program.
On Disk C Programs (x86), rename Folder (Fldigi-4.1.08 A)
Then, Fldigi-4.1.08 A copy folder A, make new ones renaming them Fldigi-4.1.08 B - C etc ...
In the directory of each instance insert configuration XML files (SmartSDR_SliceA) -B-C-D
Create icons on the desktop from the four executive program folders named fldigi A-B-C-D
With right mouse, on icon A select Properties and on (Destination :) add to already existing "C: \ Program Files (x86) \ Fldigi-4.1.08_Slice A \ fldigi.exe", write, do not copy / paste, below with space --config-dir more space, and from (From :) copy and paste "C: \ Program Files (x86) \ Fldigi-4.1.08_Slice A"
This is the full string set to (Destination :): "C: \ Program Files (x86) \ Fldigi-4.1.08_Slice A \ fldigi.exe" --config-dir "C: \ Program Files (x86) \ Fldigi- 4.1.08_Slice A "
So on for all four A-B-C-D instances
--config-dir "C: \ Program Files (x86) \ FLdigi A"
--config-dir "C: \ Program Files (x86) \ FLdigi B"
--config-dir "C: \ Program Files (x86) \ FLdigi C"
--config-dir "C: \ Program Files (x86) \ FLdigi D"
Restart P.C.
Start Smart SDR, configure four COM (X) for CAT with A-B-C-D slices
On Smart DAX activate the four RX Streams Slice A-B-C-D / 1-2-3-4
On Smart DAX activate TX Stream
Start the program from icon A and configure it:
Operator, sound card, RigCat XML file with description of the radio with slice A (configuration I can provide it if necessary), Device COM (X), Stop bit (1), Sift Use RigCAT, Sift Use Rig CAT to control PTT and browse Enable VSP, Initialize-Save and Close
Etc ... for all instances with slices A-B-C-D and for Audio card, browse PortAudio and configure Capture: DAX Audio RX 1-2-3-4 (FlexRadio Systems DAX Audio) and Playback: DAX Audio TX (FlexRadio Systems DAX TX) save and close
On DAX, adjust Volumes of RX and TX (also set Macros in TX)
With the use of FLdigi on different frequency bands, activate Full Duplex FDX
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
