FlexRadio 6400 rebooting with Transverter / XVTR provisioned
- When I provision the XVTR 2m in the Radio Config, I can work 2m just fine. Transverter works great - the Flex works great.
- When I exit SmartSDR, and try to go back in with the same computer, it causes the Flex to reboot every time I try to fire up SmartSDR.
- The only way I can get back in on my main computer is to use a different computer, and delete the XVTR for 2m in the Radio Config. Then I can at least open SmartSDR on my main computer.
- One other item of interest: If I provision the 2m XVTR in Radio Config, AS LONG AS I SWITCH TO AN HF BAND, before exiting SmartSDR, Everything works just fine... I just have to remember to not exit SmartSDR before switching to a band other than the XVTR 2M band.
I opened a ticket this afternoon, but since they are off until Monday, I thought I would reach out to see if anyone else has this issue.
TJ
K9KJ
TJ, First what is your version of SSDR?
Then Go into your transverter use it briefly and before you shut down the radio select back to HF and then shut down the radio. Then go ahead and boot it back up and see if it automatically goes bonkers.
For the last 6 months I have had my radio setup for using one of the 5 band transverters. Someday I will have one. So my 6500 is all programmed up already for 2, 222, 432, 903, 1296 already. I can click through those bands, and the radio behaves normally even though there's no transverter hanging on there. The rig is just a 10 meter radio with antenna connections steered through the Transverter port and in low drive power instead of the ANT jack... I have never shut the radio down with the rig in the VHF/UHF stuff still running. BUt I don't know if that should even be an issue.
Erika KØDD
[{"insert":"Hi Ericka!\nI have version 3.1.12. I should've mentioned that.\nI did just looked you said and yeah... Unfortunately it does still go bonkers. \nFor now I'll just make sure I switch to like 20m before I shut down. If I do that, everything is cool.\nNow that I have my transverter for 2m, I kind of want one for 222 and 70cm. I shouldn't have sold all of my antennas!\n:-)\nTalk to ya,\n\nTJ\nK9KJ\n\n"}]0
[{"insert":"Ok... Not sure why my post looks like that...\n"}]0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 247 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
