Where dose slice master look for JTDX
A41CK
Previously JTDX was showing in Slice master I bought a new PC and download everything however now JTDX dose not appear in slice master both are in Drive C. I did the default installation and also tried moving the files to AppData folder but no luck. I tried WSJT-X it dose appear.
JTDX recently changed its default installation folder so Slice Master does not know it now. Therefore edit Slice Master config.ini file to point to the C: drive location. It could be c:JTDX64 depending on the version of JTDX you have. It could even be in a sub-folder, for example c:JTDX64151_4 - you need to find it and edit the ini file accordingly.0
Hi all
Where is the config.ini file located ? (version 0.10.7c)
Thanks + 73
Paul F6EXV
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
