Where dose slice master look for JTDX
A41CK
A41CK Member
edited June 2020 in Third-Party Software
Previously JTDX was showing in Slice master I bought a new PC and download everything however now JTDX dose not appear in slice master both are in Drive C. I did the default installation and also tried moving the files to AppData folder but no luck. I tried WSJT-X it dose appear.image
  • Erik Carling EI4KF
    JTDX recently changed its default installation folder so Slice Master does not know it now. Therefore edit Slice Master config.ini file to point to the C: drive location. It could be c:JTDX64 depending on the version of JTDX you have. It could even be in a sub-folder, for example c:JTDX64151_4 - you need to find it and edit the ini file accordingly.
  • Paul F6EXV
    Paul F6EXV Member ✭✭
    Hi all
    Where is the config.ini file located ? (version 0.10.7c)
    Thanks + 73
    Paul F6EXV
