antenna genius connection
AK1MD
in Networking
Each time I start the computer and open the Antenna Genius App I need to pull the plug from my LAN switch out and replug it back in to trigger the Antenna Genius software to start working. It looks as if the switch/antenna genius is not recognising the DHCP address and need to be rebooted. Any suggestions appreciated. Thank you.
73, Alex AK1MD
73, Alex AK1MD
Sounds like you may have a network issue. Can you describe how the network is configured?
Also, can you check what version firmware is in your 2x8 switch? Under device info in the utility program.
Problem solved by unchecking DHCP and configuring IP address, subnet and gateway in Antenna Genius.
73,AK1MD
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
