antenna genius connection
AK1MD
AK1MD Member ✭✭
Each time I start the computer and open the Antenna Genius App I need to pull the plug from my LAN switch out and replug it back in to trigger the Antenna Genius software to start working. It looks as if the switch/antenna genius is not recognising the DHCP address and need to be rebooted. Any suggestions appreciated. Thank you.
73, Alex AK1MD
  • David Decoons, wo2x
    Sounds like you may have a network issue. Can you describe how the network is configured?
    Also, can you check what version firmware is in your 2x8 switch? Under device info in the utility program.
  • AK1MD
    AK1MD Member ✭✭
    Problem solved by unchecking DHCP and configuring IP address, subnet and gateway in Antenna Genius.
    73,AK1MD
