No microphone audio
I am not getting any microphone audio using SmartSDR for windows. Microphone works fine when just using the Maestro. Microphone is selected in menu and Mic stream is on in DAX. Any suggestions to the proper settings?
Hi Doug, What radio and software revision are you using? Where is the mic connected (some Flex radios have multiple mic connectors)? Are you using a USB mic plugged into the PC?
Depending on the answers, turning on DAX could be the problem or the solution.
Len, KD0RC
The mic is connected to the RJ45 connector on the Maestro and it works find when just using the Maestro. Not using any mike plugged into the computer.
Flex 6400 running v3.1.12
Hi Doug,
It may be that you need to go to the multiFLEX dashboard and set PTT to your Maestro. You may also need to drop down the MIC selector to choose the Maestro mic. On my 6400 (no Maestro) my options are MIC, ACC or PC. I am not sure what your choices will be if you have the Maestro connected using multiFLEX, I don't have one to test this out with.
Len
Silly question, how do I access the multiflex dashboard. I don't see it anywhere?
Settings, multiFLEX from SmartSDR. I am not sure if there is a corresponding Maestro menu.
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
