Slicemaster only displays WSJTX
Suddenly, Slicemaster V10.7.c only displays WSJTX on each slice window....
I uninstalled and deleted the ini file.....same problem....
Help.....
Tim
wa5yom
  • Lou KI5FTY
    Lou KI5FTY Member ✭✭
    I had the same question after Installed it.
  • WA5YOM
    WA5YOM Member ✭✭
    Still no luck......
    I have uninstalled.... tried different versions....still doesn't work
  • Dave Garber
    Dave Garber Member ✭✭
    did this get solved for you. Me, I have to edit the config.ini file ( make sure slicemaster is not running) and correct the default path I have , as it is not the default install path
    I now have wsjt-x, jtdx, had js8call, and cwskimmer all running on D drive and working fine. trying n1mm next
