Slicemaster only displays WSJTX
Suddenly, Slicemaster V10.7.c only displays WSJTX on each slice window....
I uninstalled and deleted the ini file.....same problem....
Help.....
Tim
wa5yom
I had the same question after Installed it.
Still no luck......
I have uninstalled.... tried different versions....still doesn't work
did this get solved for you. Me, I have to edit the config.ini file ( make sure slicemaster is not running) and correct the default path I have , as it is not the default install path
I now have wsjt-x, jtdx, had js8call, and cwskimmer all running on D drive and working fine. trying n1mm next
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
