Meastro connects remote, SmartSDR fails remote
Smart SDR 3.1.12 connects to 6700 on local LAN, Maestro connects remotely via SmartLink, but remote Smart SDR says "There are currently no radios available" and hangs, such that pressing "log in" or "SmartSDR setup" sounds an error note, then I cannot terminate SmartSDR except with Windows Program Manager. SmartLink test is green at radio site. OS is Windows 10 Pro 19042.685. Worked fine yesterday. What am I missing? Do I have to re-install SmartSDR?
Update: After a windows update and reboot, the SSDR app
runs but the somehow the login information was deleted. I could select login without an error tone and then reenter the login to SmartLink info. Weird but works now. 73 John N5CQ
Update: another PC is able to log in remotely using SmartSDR so the problem seems to be one just one computer. DAX and CAT work as normal when I log in with Maestro, but Smart SDR will not.
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
