DAX audio bandwidth 96 kHz with 192 kHz sampling ????
in DAX
Hello...
in my need to stream audio to Linrad software I need to get DAX audio bandwidth 96 kHz with 192 kHz sampling ...but I cant find any way to setup the bandwidth or sampling for DAX
any help ????
73" OZ1CT Ben
Hi Bent,
I assume you are looking for IQ data, right? At the bottom of the DAX panel, you can set the sample rate (max of 96000). I don't know how to set the width, but you could experiment with the panadapter width and see if that influences the IQ data.
Len, KD0RC
HI Len
No I was looking for the bandwidth of the DAX audio and also the sampling rate ??? not the IQ streams.
73" OZ1CT Ben
Trying to use my setup (Flex 6600 + transverters) with satellite's telemetries.
How could I expand the width of the audio DAX? It's always about 5.500 on the hs-soundmodem waterfall
Thanks and 730 -
The DAX audio stream is the same as the receiver slice audio stream. You can set your audio bandwidth in SmartSDR.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
