DAX audio bandwidth 96 kHz with 192 kHz sampling ????
Hello...
in my need to stream audio to Linrad software I need to get DAX audio bandwidth 96 kHz with 192 kHz sampling ...but I cant find any way to setup the bandwidth or sampling for DAX
any help ????
73" OZ1CT Ben
    Hi Bent,
    I assume you are looking for IQ data, right? At the bottom of the DAX panel, you can set the sample rate (max of 96000). I don't know how to set the width, but you could experiment with the panadapter width and see if that influences the IQ data.
    Len, KD0RC
  • HI Len
    No I was looking for the bandwidth of the DAX audio and also the sampling rate ??? not the IQ streams.
    73" OZ1CT Ben
  • ea5wa
    ea5wa Member ✭✭
    Trying to use my setup (Flex 6600 + transverters) with satellite's telemetries.
    How could I expand the width of the audio DAX? It's always about 5.500 on the hs-soundmodem waterfall
    Thanks and 73
    The DAX audio stream is the same as the receiver slice audio stream. You can set your audio bandwidth in SmartSDR.
  • ea5wa
    ea5wa Member ✭✭
    edited May 2025
    null
    Hi Mike:
    Even with 24kHz bandwith (DFM mode) when I send the audio to hs-soundmodem software, I only have a 5,5 kHz audio bandwith, not enough for 9k6 satellites.
    What could be the reason?
    73 de EA5WA Juan Carlos
