cw skimmer
Odd issue I'm having.. with slice Master opening CW skimmer, It appears to be functional in that slice master thinks its running and I do get spots on the SDR software but the skimmer window will not open. Hovering over the icon in the system tray I see only a white box.
If I try to open Skimmer without slice master then The program opens to the typical window you would expect to see . that is the band on the left with all the calls on the right side.
Anyone know what I set in slice master to cause the program window to not open?
    Hi Troy, I had a similar problem with mine. The solution was to delete the config.ini file. In my case, it was here:
    C:\Users\lenko\AppData\Local\K1DBO\slice-master\config.ini
    It will be rebuilt automagically if SliceMaster doesn't find it.
    Len, KD0RC
  • Troy NW1B
    Troy NW1B Member ✭✭
    Len,
    Thanks for the help. I found the config file and deleted it. Slice Master did reconfig but with the same results.
    I'm leaning towards a video display issue as every indication says the program is running 100% but I just can't see it. I'm going to break my system down to a single monitor and low res and see what comes of that.
    73 Troy
  • Troy NW1B
    Troy NW1B Member ✭✭
    for those interested I finally came to understand what the issue was. slice master 10.7.c needed to be completely deleted and then rerun . \nit came up as a new **** run and reconfigured everything. all is back 100% now
